Terminator 998 Header pics....
Age
50
Canada
2017 998 turbo
We have 3 different versions built and are going to get them flowed to compare with the competition.
Fitment is bang on, will be interesting to see the difference with a merge and slip on collector!
This is version 3
This is version 3
Nice!
Questions:
- will they have adequate clearance to use with stock fuel tank?
- will the header have the tabs to mount the stock heat shield?
This is version 3
Whats it worth?
Clearance to the tank is a non issue, all tabs will be in place! This is just a prototype so once we know which one flows comparable to the competition we will release that one.
We have a few different designs with tubing, bends and collectors so it will be interesting to see the difference. We have other manufactures here so we will get those flowed too for an accurate comparison as we would like to be in the ball park for tune reasons.
Here are some more pics....
Version 1-
When you say clearance to tank is a "non-issue" does that imply you will have more clearance than the "others" because most of rest one tube or the other is pretty close to tank (closer than stock manifold). Close enough to cause me to spend time improving the tank insulation considerably. I didn't like the idea of having a red hot metal tube within an inch of my plastic gas tank even with the factory heat shield.
Also, how about clearance to the coolant hose on left side?
Thanks Mike, great job! Really looking forward to seeing your test results!!!!
