Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
I got the Arctic cat/Yamaha tether for Christmas. My question is how in the crap do you get the little pin out of the factory harness? I tried pushing on it and nothing. The instructions are very vague on how to do it so I'm hoping one of you guys knows how. All I can think of is to cut the wire and do it without taking the pin out but I really don't want to cut my factory harness.
Can you take a pic of connector?
jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
you just unlock it with a needle,pull the wire out of the conector.I got the Arctic cat/Yamaha tether for Christmas. My question is how in the crap do you get the little pin out of the factory harness? I tried pushing on it and nothing. The instructions are very vague on how to do it so I'm hoping one of you guys knows how. All I can think of is to cut the wire and do it without taking the pin out but I really don't want to cut my factory harness.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I agree with jpr-ltx-dx, use a needle or thin paper clip
Dirtbikekid1998
- Mar 3, 2013
- Maine
Thanks guys! I thought it had to be something stupid it came out
Will any normally closed tether work the same way as the ' original' ?
Yes but it wont have the connector pins on it. I would go with OEM or get the Rollover valve which also uses a tether.
Does the tether only brake the cable from the kill switch when pulled out?
Yes
jakehayamaha
Where do you find the tether kit?
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Any Yamaha dealer can get you the kit for Viper. Install is pretty easy as well once you get the hang of getting the wire out of the connector. Paper clip in the hole works good to release the wire after you pull of the locking tab with needle nose pliers.Where do you find the tether kit?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
If you are going to the trouble to put in a tether why not get the Roll over valve as it has a reprime feature as well as an oil leak solution. More money but way more product.
X2 I wont own a 4st without it. I experienced the big oil puddle after a very light roll on right side before I got wise and got the valve. Dont even think about tipping it anymore. No more spilled oil. No more worries.If you are going to the trouble to put in a tether why not get the Roll over valve as it has a reprime feature as well as an oil leak solution. More money but way more product.
jakehayamaha
I don't plan on rollin it! LolX2 I wont own a 4st without it. I experienced the big oil puddle after a very light roll on right side before I got wise and got the valve. Dont even think about tipping it anymore. No more spilled oil. No more worries.
I never do either. If so then you dont need a tether.I don't plan on rollin it! Lol
