1. We are no longer supporting TapaTalk as a mobile app for our sites. The TapaTalk App has many issues with speed on our server as well as security holes that leave us vulnerable to attacks and spammers.
    Dismiss Notice
The Hurricane clutch noise elimination shaft
Discussion in 'SideWinder Trail Talk' started by HURRICANE, Sep 21, 2018.
  1. HURRICANE
    HURRICANE Advertiser Advertiser VIP Member
    2,032
    Prescott Ont.
    428376EF-B6CE-4327-BA5D-C1C7FE7E28AF.jpeg We are ready to sell the Hurricane sidewinder clutch noise elimination shaft. This has been thoroughly tested all summer in the Hurricane promod sled making 340hp. This stub shaft replacement dramatically reduces the engine harmonics before they reach the clutch thus removing the rattles. This stub shaft also helps to quiet the Stm clutch while making the clutch much more durable. There is thought to actually be a gain in overall hp of the engine as a result of the Hurricane harmonics reduction shaft. The price is only $499us
    1nc 2000, Snowman871, TT and 2 others like this.
  2.
  3. **sj**
    **sj** Lifetime Member Lifetime VIP Member VIP Member
    6,039
    southeastern Mich
    Country:
    Snowmobile:
    2019 SRX
    nice job hurricane
  4. fatchance
    fatchance TY 4 Stroke Master
    1,054
    Ma.
    You know this topic will come up so do you want to elaborate....... No worries with crank bearing longevity Dave?
    ROCKERDAN likes this.
  5. NYTurbo
    NYTurbo TY 4 Stroke Junkie
    557
    Ottawa
    Country:
    Canada
    Snowmobile:
    Sidewinder
    Nice job. Imagine it may change clutch offset ?
  6. ROCKERDAN
    ROCKERDAN OCD Sledhead VIP Member
    7,354
    Huntsville Ontario & Niagara NY
    Country:
    Other
    Snowmobile:
    '18 RTX 50th "Winder"
    Wow, great work Dave.
    As you know, Many of us would love a more in-depth post of specifics.
    Also how much work it is to install.
    And will this aid in belt wear do you think?
    Sure would be nice if it helps with primary roller life too.
    Congrats on this piece!
    Dan
  7. HURRICANE
    2,032
    Prescott Ont.
    We had this shaft made to move the clutch out drone the engine 1/8inch to fix the offset problems. It’s a ten min job to install
    Tarzan likes this.
  8. ROCKERDAN
    7,354
    Country:
    Other
    Snowmobile:
    That was a smart move to include Dave....since we all seem to have to machine the rear of secondaries, great!
  9. fatchance
    1,054
    Ma.
    Just add the spacers back in Dan
  10. ROCKERDAN
    7,354
    Country:
    Other
    Snowmobile:
    yep easy peasy for sure...
    Anxious to get some feedback from guys who try this....and would love to see some vids/pics of the install....I almost wish i was doing one ASAP and could document it all.....Just sorta sick of throwing every last penny into this girl. LOL
    Dan
    Chris Rose and fatchance like this.
  11. cannondale27
    cannondale27 Moderator Staff Member Moderator Vendor Lifetime VIP Member VIP Member
    18,855
    Manitowoc,WI
    Are you guys reusing the original bearing and housing? Press fit?
    fatchance likes this.
  12. Chris Rose
    Chris Rose Expert
    212
    Powassan ONT
    Country:
    Canada
    Snowmobile:
    2017 sidewinder stx-DX with TD/Max 16 stock muffler
    WEBSITE:
    chrisjrose2018@@gmail.com
    If you have a service manual, check pages 28 & 33 on replacing the "output shaft".
  13. PAvector
    PAvector Lifetime Member Lifetime VIP Member VIP Member
    172
    Pennsylvania
    Is it available for Viper’s?
  14. HURRICANE
    2,032
    Prescott Ont.
    This is only available for the 998 motor because the crank sensor is in the way on the 1050 motor
  15. WinterWolf
    WinterWolf TY 4 Stroke Guru
    977
    Connecticut
    Country:
    Snowmobile:
    "2018 Yamaha Sidewinder RTX LE 50th Anniversary Edition"
    So if one gets this clutch noise elimination shaft...this will also solve the offset issues with the sidewinder clutches..period? Am I understanding this correctly?
    I was thinking of ordering Dave’s clutch alignment tool soon to make sure my offset is correct; if you buy this piece, is that still necessary or not?
    Surprisingly, I actually was not bothered by my clutch noise like I thought I would have been. But if this fixes the noise and the alignment too...might be something to think About...just as long as it doesn’t cause any other side affects??
  16. WVTurboLTX
    WVTurboLTX TY 4 Stroke Guru
    859
    Hedgesville, WV (ride in Deep Creek, Maryland)
    Country:
    Snowmobile:
    2009 Nytro XTX
    2017 Sidewinder LTX LE
    You will still need to check your alignment. They are not all off by the same amount. Most people are having to machine the hub to bring them into alignment. This 1/8" extra should eliminate the need for that and allow you to adjust the number of shims behind it instead.
    staggs65 and ROCKERDAN like this.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
