Does anyone know what the thread is for the nylon nut that tightens the rear axle? The below numbers are from the fiche. The collar goes around the axle and the nut is what is adjusted to tighten the tension on the track. One of mine is gone and don't know for how long. Noticed movement Sunday.Thought the rear wheel was going at first.
The two small adjuster screws are 10mm in diameter but they seem to have a non standard pitch because I can't get either the coarse (1mm) or fine (1.5mm) pitch die on them. I think they are M10 x 1.25mm- good luck finding that at Home Depot.
If you mean the axle shaft the thread OD is 14mm so if it's a fine thread it will be M14 x 1.5mm and if it's coarse it will be M14 x 2mm (unless it's a non-standard pitch too).
