gpxsrx
https://thunderproducts.com/product/tpi-secondary-clutch-springs/
Has anyone tried this secondary spring in a 190 hp Hurricane turbo?
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I cant speak for a Hurricane setup, but it works awesome in my mpi 190 turbo
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
same running it in a mpi with 7psi
- Apr 14, 2003
- Hessel, Michigan
Works awesome in my OSP 6.5 psi turbo about 210 horse
jeffgilbert
- Dec 17, 2007
- Newfoundland
i found it very responsive i only have limited testing due to snow but i was pulling along at 70 mph 1/4 throttle and when wot and it would pull the skis right off the ground.
(21/41 gears, reverse helix 40/46, 60y super tips, tpi orange secontadry, 14.5 rolers, gates 8jp size belt)
gpxsrx
Ordered mine today, Been using the purple spring that came with hurricane kit it robs top end i think.
Reverse helix 40-46 work well for flat land ?
i have been trying 51-43 and 46-40.
sgauthier
Would the orange TP spring also work in a stock viper?
rx1 fern
Yup. I run it on mine . Full exhaust and airbox mod also
PAvector
What setting....3-2?Yup. I run it on mine . Full exhaust and airbox mod also
rx1 fern
- Apr 14, 2003
- Hessel, Michigan
Yes
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
Being it is such a stiff spring, I don't understand how this would help out a sled vs the stock pink. I feel like it would make the sled snappier yet, but in a drag application it would create to slow of a shift and not load the engine as hard as others. Am I correct on this or ?
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
I'm interested in this spring also running the hurricane kit in mine to but has a green spring wound at 10 deg. with a Dalton helix stamped 1535. Anyone know off hand what kinda spring this is and I have know idea what the deg. is on the helix. I would like to make some changes on this set up but don't really know what way to go because I have no idea what's in my sec.
- Apr 14, 2003
- Hessel, Michigan
Clutching is a complete science to get everything to work together. This spring has done nothing but amaze me and the people who have tried it. The stock Pink is the strongest spring, but has too many coils and binds on top end. The new orange secondary spring has less coils to eliminate coil bind, has a little more side pressure and a little more twist percentage, but I think because of the less coils the spring works easier on top end. I do not know the specifics of this spring....just know it works.
Maybe get a poll going to see? All I know is that the springs are selling like crazy and Lonn is ordering more again.
yammitrip1
- Sep 28, 2017
- Rome ny
By all means I am not arguing with you, it may work. It may not! There's only one way to find out. Now I have to buy one lol. But I'm just saying my pink spring hooks and works every where. I have spent some good amount of time with clutches, so I understand the science.
Are you implying the pink is stronger then the orange??
