black john
does anybody know who mite make titanim gears.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
can i ask why you would want to run titanium gears?
kmer
he 'thinks' his 'black' sled has so much power.... that it's gonna eat those steel ones... :lol:
black john
Ti gears = 1 lb of rotating mas is worth 7lb of unsprung mas better xeleration thats all and thats all . thay came stk in the 76\77 srx and the 78 ssr,s just one more edge thats all. and kemer hummm a slam dont forget that i know where you live :lol:
- Apr 17, 2003
- Menno, SD
- Menno, SD
black john, there's not much difference in weight at all between titanium and the stock steel gears. go with an aluminum bottom gear and you'll save more weight. plus gears don't have that big of a diameter at all so you don't really notice the change in weight because it's not that far off of the centerline unlike the secondary or brake disc, etc.
black john
yes i also ran that one of the aluminum gears up the flag pole but thay wear to much for trial use. all that i have came up eith so far is to use polaris lower gears thay are a little less materal on them. or use the a/c trick of running two differnt width gears ie slim lower and thick on top. and if it,s not that big of a thing why would manufactures got to great lenths such as to make ti gears and install them and use two differnt width of gears ? it must make some differnce just the fact that aluminun gears are out there should mean some thing 8)
- Apr 17, 2003
- Menno, SD
- Menno, SD
Black John, just trust me when I say it doesn't make that much of a difference. I've done alot of testing and trying all those products. If you really want to take advantage of the rotating weight then buy yourself a double diamond direct drive or a RMI direct drive unit. I just couldn't justify the cost of a TI gear on a trail sled. Not worth it in my eyes.
kmer said:he 'thinks' his 'black' sled has so much power.... that it's gonna eat those steel ones... :lol:
Those poor guys that own the black ones...... They have to really grasp at straws to try and catch us blue guys!! :lol:
black john
thanks. it was just an idea . and kemer dont you ever work :lol:
Climbmax
Just run the Polaris hyvo bottom gears.......lot lighter and easily available.
Just shim to back side equal to OEM and you'll be good to go!
CM
CM
