Top Gear
stomper
Saskatchewan, Canada
OK, I read it on here somewhere last year but cant find it now. I am wanting to drop a smaller top gear in my chain case from stock on my 03 RX1. What do I switch to and will I need a new chain also or can I get by with my stock chain. What can I expect in performance by doing this.
The 03 came With 24-38 gearing.
It's a 70 link Chain.
You can go to 23-38 without changing the Chain.
At 22-38 you will have to change the Chain to a 68 link Chain.
The change in performence will be small.
You will get out of the hole faster depending on tracktion. I would go Down one tooth to 23-38 first. Sprockets are cheap, Chain is not.
I have a 2005 RX1 with jets K&N filters and snow socks. M10 suspension would I gain or lose top end if I change the top sprocket from24 to 26 tooth. I am running 10,100 rpm full throttle. Thanks in advance. jj
You will not have the Power the pull the 26/38 gearing. I run 25/38 at 350 HP and I'm able to run it out of gear, on a stocker you're not.
You will not gain top speed gearing up to 26.
I recommend gearing Down a tooth to 23, you will get better low end response and even gain a few at top end.
harleyrider557 - you're welcome.
Would you mind adding Your location to Your user profile, site requirement.
rxrider
TY Management Team
gearing
hey guys stock gearing is way to tall if it would fill clutches it would go 125mph.i have mine geared 22-39 and on radar its shows still iio mph the advantage by gearing down is much better midrange but remember when you gear down alot clutching is necessary/
With a 70 link chain you can go to a bigger bottom gear as well. The o4 mountain came with a 21/40 gearing with a 70 link chain. Making your bottom gear bigger is going to give you the same effect as going with a smaller top gear only its more efficient. You will lose top end speed but gain torque. You can go as high as I have with a 24/40 70 link combination.
Thats what I am after is the torque. My sled will do 110ish mph now and I rarely drive at those speeds, but I do love the powder riding and twisty trails. I love the feeling of the butterfies in my stomach when I hit the throttle. What kind of top end speed will I lose? 5, 10, 15 mph???
Want butterflies, a turbo system would do that LOL :-)
