Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
All the same yamaha 4 wheel kitAlso make sure the wheels are correct diameter and same for all 4.
Carla 123
- Feb 27, 2017
- Lester beach
What do you mean by this?Thats a good start for pics. Need Trihub and adjusters. You are looking at the clips to rail outside right?
Track is aligned to the rails not the wheels. As far as pics I am looking for something wrong. Width wise from one side to the other. Just because its a kit doesnt mean its the right one.What do you mean by this?
Carla 123
- Feb 27, 2017
- Lester beach
Track clips to rails is still out.why wont the track move over.that is the issue.tri hub wheels are rubbing on track nubs
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
You could try keeping the side the track needs to move toward tight and only loosen the hub bolt on the side your going to tighten. This would keep one side stationary so when the opposite side is tightened the tri hub would offset enough to push the track over.
Carla 123
- Feb 27, 2017
- Lester beach
Tried that.
Carla 123
- Feb 27, 2017
- Lester beach
Really appreciate the help guys.it seems like something is binding not allowing it to move over at all.anyways I guess I will pull the skid again and go through it because something is not allowing it to move over.i even took the 4 wheel kit off and the adjuster is moving but the tri hub is not going over to the right
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Why did you pull the skid to remove the tri hub? You can remove it with the skid in.
Carla 123
- Feb 27, 2017
- Lester beach
Broke an adjuster bolt as I didn't have the idler loosened off so had to pull skid to get the broken bolt outWhy did you pull the skid to remove the tri hub? You can remove it with the skid in.
Take a bunch of pics. Maybe we can spot something. How about the drivers. How do they look as far as alignment with track?
Carla 123
- Feb 27, 2017
- Lester beach
Tomorrow as I've had enough of this today.the idler wheels at the front of the skid look lined up pretty good.what do you want pictures of?Take a bunch of pics. Maybe we can spot something. How about the drivers. How do they look as far as alignment with track?
Everything at rear of skid. Sleep on it. Sometimes that helps alot. Night.Tomorrow as I've had enough of this today.the idler wheels at the front of the skid look lined up pretty good.what do you want pictures of?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
pull the tri hub, flip it over and reinstall.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
How tight or lose is your track. I am of course referring to track tension. If the track is too tight it could act up.
Carla 123
- Feb 27, 2017
- Lester beach
Don't know why that would make a difference but at this point I will try anything.thankspull the tri hub, flip it over and reinstall.
- 9K
