Bert Corrigan
My 2019 SRX Sidewinder w/Turbo Dynamics tune and other mods, runs 141 mph radar on ice. I’m running 1” of track deflection at 17lbs.
Can others here tell me what I should be running for track deflection on a sled running this speed on ice.
I know the track must be tighter than you would normally adjust for trail riding. But how tight is right for high speed ice runs?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Sounds like your doing just fine with where your at? Any way to test back back with different tensions? That would be ideal way to know. IMO you could go tighter. But I’m just a trail guy.
sideshowBob
141 mph!!!
Sounds like you should be telling most of us how to set up our sleds.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Is it possible to over tighten the track ?141 mph!!!
Bert Corrigan
Thank YouSounds like your doing just fine with where your at? Any way to test back back with different tensions? That would be ideal way to know. IMO you could go tighter. But I’m just a trail guy.
Bert Corrigan
Thank You. I don’t know if it’s possible to over tighten a track. I’m sure at some point where rolling resistance is met that horsepower is being robbedIs it possible to over tighten the track ?
Fleecer
- Jun 13, 2014
- 2019 SRX
141 mph!!!
Impressive numbers for sure. Inquiring minds want to know ...... clutching, gears, distance?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
4 miles.... lol
Bert Corrigan
23top/Dalton/2500’Impressive numbers for sure. Inquiring minds want to know ...... clutching, gears, distance?
Bert Corrigan
Funny4 miles.... lol
Bert Corrigan
Bert Corrigan
My speed of 141 was achieved in 1000’ on a 2500’ track.Actually
Fleecer
- Jun 13, 2014
- 2019 SRX
Very impressive, especially in 1000ft!!
Which tune?
Just curious, you mentioned 23 top gear, is that mated to stock 41 on bottom? No chain fits that ratio, how did you make that work?
Bert Corrigan
The key to all those seeking better top end is to have both the primary and secondary clutches machines to allow the shift up to overdrive. Do this before making gearing changes.Very impressive, especially in 1000ft!!
Which tune?
My 2019 SRX is set up as follows:
TD Power Trail Tune
3” Cold Air Intake
Bert Corrigan
Turbosmart BOVThe key to all those seeking better top end is to have both the primary and secondary clutches machines to allow the shift up to overdrive. Do this before making gearing changes.
TD Power Trail Tune
3” Cold Air Intake
Every rotating shaft in skid trued to + - .002 runout.
Dalton clutching
23 top 40 bottom chain case
- 40K
- 28K
