Spicoli
- Dec 8, 2016
- Waterford, Ontario
- 2018 Sidewinder L-TX DX
I have a stud pulled out on my track. How do I repair it? It has left a hole. Please help.
Sent from my SM-T310 using Tapatalk
Buy a new track. There is no way to fix it other than have a track repair company vulcanize it but it will never be as good as a new track.
HighSpeedLowDrag
You can remove all of the studs, an old track will start to lose more of them. If its far enough from an edge and can be trimmed to a round hole with no loose rubber it can be used for a while. Look at track porting.
kingtut
If it's only one stud just leave it and ride. When you have a bunch pull out then I'd consider getting a new track and then it starts fraying then new track or die. It's just like missing lugs really.
Spicoli
- Dec 8, 2016
Well I bit the bullet and bought a new Ripsaw with 96 studs to go on. I am going to install myself, I am very handy and learned a lot about this machine just doing an oil and filter change (lol). Any helpful advice on this challenge? I did read some past posts on the subject. With the suspension out I am going to change some idler wheels and the sliders for sure. Should I change or just grease the drive Shaft bearings? (7800kms on sled) Either way what is the best type of grease? This sled has been babyed and only had oils changed. Thanks in advance, this site rocks!!!
sgauthier
if it was me and for the price of the bearings/seals i'd replace them all and be done with it. a lot easier when you have it all apart.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 14600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 19500 km
2010 Vector LTX GT 25000 km sold
I agree with sgauthier, I had a 2010 Vector that I was putting 5000-5500 km each year on extended trips. Pulled the skid each year and changed all bearings each year for NTN formula bearings on all idler wheels which included oversized 135mm wheels for slider life. New sliders each year regardless of wear and new drive bearing each year. Replaced secondary jackshaft bearing every second year along with chain case rebuild at same time. Did my own work and only worries were on overnight trips was during minus 30-40 starting issues.
