tippmannator
Got a 2013 nytro xtx....stock track is 144X1.75....what is the tallest lug height I can run without major mods?
tippmannator
Anyone?
radianguy
- Jan 1, 2007
Stock track on the nytro was 1.25", to put a 1.75" track on you had to remove tunnel protectors. A lot of guys including me did this before Yamaha's offered it as an option. With that said I believe you can put a 2" track on there, I remember seeing guys doing it way back when everyone started doing the 1.75" track swaps.
tippmannator
2013 nytro came with the 1.75.... so If I remove thw tunnel protectors I can go 2 inch?
radianguy
- Jan 1, 2007
I know that, tunnel protectors are not in your sled.2013 nytro came with the 1.75.... so If I remove thw tunnel protectors I can go 2 inch?
tippmannator
Ok so I should be able to fit 2" lugs on a stck xtx?
walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
1.75 lug is an awesome crossover track!!!
tippmannator
Thats what I have and I like it.... but I was trenching out alot this winter.... want a bit more bite
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
I find my XTX trenches horribly with the limiter straps all the way out. If I pull them one notch then it changes the off trail characteristics totally! I hardly ever get stuck no matter how dumb of a move I pull, stop and take off wherever without an issue.
Before spending all that money I would try improving the approach angle by pulling the limiters one notch. It just sucks that it makes steering harder by doing so.
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
You might want to post this in the mountain section. I think if you go down 1 tooth in drivers you can put 2.25 in it. Don't quote me though
striker606
- Feb 11, 2014
- Maplewood MN
- 2009 yamaha nytro xtx
I have a 2" on mine and love it. removed tunnel protectors and went with smaller drivers. I believe they are 8 tooth drivers
