burg226
- Jan 24, 2011
- Newcastle, ON CANADA
- 2017 Arctic Cat 9000RR
I have a small tear less than 1/2 inch wide on the outside of my fairly new ripsaw track. The tear is right through the track but only goes a 1/2 inch deep from the ouside of the track inwards. Replacing the track is out of the question at this point however I would like to attempt to repair it.
Just by doing some research I have read up on people suggesting Gorilla Glue, E6000 and other industrial materials. Has anyone repaired a slight tear successfully on there own? If so, what did you use? I'm looking for a commonly available product I can purchase at Canadian Tire, Home Hardware, Walmart, etc.
smokingcrater
I highly doubt gorilla glue would hold up very long. My personal experience with GG is that it does well if it doesn't have to hold up under cold or flexing conditions. I've seen it actually shatter when cold! I can't imagine it lasting more than a couple of times around the cogs and it would be done.
Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
track
I doubt the glue will work...there use to be a place in Ontario that did track repairs.....I don't know if they are still in business..
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Call Camoplast and see what they say?
smokingcrater
Re: track
The track repair places I've seen used vulcanization techniques, which is worlds apart from any form of glue. (think chemically melting and reforming.)
Newfie Apex said:I doubt the glue will work...there use to be a place in Ontario that did track repairs.....I don't know if they are still in business..
Caveman
- Sep 13, 2012
- New Hampshire
- Yamaha, Polaris, SkiDoo.
I've used a urethane based windshield sealer the installers use..black, flexible, strong. Clean it well with acetone, then apply and let it dry 2-3 days before using. Wear rubber gloves. My repairs to an old Skidoo and an FST have lasted a few years now. Get it fully inside the tear and you should be all set.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
X2 on the windshield urethane. I had a peeling type rip in a track I picked up for $50. I used the urethane as well as a large needle and cord to also sew it. I would heat the needle with a propane torch and pushed it through the track. About 1000Km, still good.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
e6000 is pretty good stuff. I repaired a rip with it and it lasted the rest of the season till I replaced the track. I used cord too because it was on the side and all the way through.
Yamasquaw
- Nov 26, 2005
- 40 km's west t.bay
- 2009 Nytro,2002 Viper
Like smokingcrater said Vulcanization. Industrial belt places might lead ya in the right direction.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
Shoe goo works great.
