maxdlx said:Grimm said:Yes you can force them through the track windows. Lube the track window and it will be easier. Since you have reverse, pull out the sliders about 6 inches through the windows, start the sled, put in reverse and hit the throttle. The sliders will pop off like nothing.
Make sure you remove the front screw first. lOL Maxdlx
The screw would have to be out to move it 6 inches through the track window. Once you have it six inches through the track window the rest comes really easy anyhow so just pull it. I lock a vise grip on and yank away it will come pretty easy. I also spray a little WD40 on the slide and let it sit first too.
RTX Rox
Are you serious?
Don't cut anything!!!!!! My god. Loosen your track a half a turn or so and round off the front of the slidder with a bench grinder. Spray some WD40 or Moovit on the slidders and tap them in. Cutt the track, come on.
maxdlx said:you just open 2 windows up with a utility knife and do it there every time. Maxdlx
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Put the sled on it's side , with out any load on the track and skid , it will go in easy , no straps etc even necessary ! Bolts line up with ease.
To remove sliders , pull screw , knock back 6 in , just thru window ( yes they will fit )
then start sled turn track in reverse , out they come , line up , lube and drive new back on , taken 15 min.
wayno
- Nov 23, 2005
Since this post is about installing new slides, I have a question about super slippery slides. I tried to install them on my 06 rage, and am having trouble with the slides cracking the flanges as they start to go the last 8 inches or so at the front of the rail. These thing are super stiff, and very difficult to install in that last 8 inches. Has any one had any experience with installing these and if so, did you have this same problem?
- 10K
