tedgoesfast
I've asked before but never got a lot of input .I want to put a 1.5 ripsaw on and stud it has anyone tried this.its a 2007 apex gt 121 track
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
I don't think there is enough room up front heat exchanger. Had one on the wifes sled w/out studs. Had to remove heat exchanger protectors.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I say the track will fit if you remove protectors but studs would then hit exchanger. There is a recent write up on this I am not sure if it was an 10 or older or not.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you should have a 1.25 track on there now jack it up and see how much room is left before the front exchanger is in the way.
Rich Kay
I went through this question when putting a 1 1/2" intense on my apex..... track fits but studding ...no. plus if studding a 1 1/2 track the studs are getting way tall and tend to be prone to "lay over" and not penetrate and subject to tear outs.....
- Jun 28, 2004
- Clinton, Wi.
I've been running a 1.5 track for 6 years with no issues with tunnel or front exchanger issues. If you haven't run a 1.5 track before your in for a pleasant surprise even with no studs.
tedgoesfast
I will have to sytasy with a 1.25 a bought a 1.5 I'll trim it down to 1.25 the lugs will be stifferand I will lay the studs to it.should hook up good on a hard trail.My bud put a 1.5 on his doo just didn't want to play catch up with him
ricer68
- Mar 23, 2016
- Wabash Indiana
- 2007 Yamaha Apex GT
- North East Indiana
I have a 1.5 intense track on mine and love it. No room for studs, I went from a 121 JUNK (ripsaw) with studs to a 136 intense 1.5 with out studs. Massive difference, the intense hooks way better then the old track ever thought about.
tedgoesfast
I will just trim track down and stud it there is a airstrip close we do some racing at so studs are a must
Rich Kay
Why not just stud the hell out of an old rip saw track and have at it....?I will just trim track down and stud it there is a airstrip close we do some racing at so studs are a must
tedgoesfast
Scared of pull out track is ten years old don't want to take a chance on hitting the cooler
Tony2323
- May 31, 2018
- Thunder Bay Ontario
- 2006 Yamaha apex rtx
So what is the most aggressive track I can put on for deeper snow? I would be looking for a 121 with no studs
Rich Kay
Have a 1-1/2" intense on my apex 121... no studs and love it. I ride in almost all loose and deeper snow and can feel the performance gain even to a point of doing some slight clutching adjustments because of the better track.
Tony2323
- May 31, 2018
Did you have to do any modifications to put that track in ? We get about 3 ft of snow here in the ditches and I found with the stock studded track it got stuck all the time which sucked!
Rich Kay
No mods to run track.....
