putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
For those of you that started out on the Trail Seat and have switched over to the Mountain Seat, what are your opinions?
I'm looking for a seat that provides a bit more height and a slight more cushion. I should also mention I do 100% trail riding, so looking for your opinions.
Byam
Almost 22 oookm on stock seat SW and viper combine. This year i have switch for the montain seat for exactely the reson you are looking for. 3100km later all could say is, i should have done this way before!
putz21
- Apr 15, 2013
- Tomahawk, WI
Great to hear! Just looking at pictures of the mountain seat, it certainly looks higher and a bit more cushion. Thanks for your feedback as you certainly have some "seat" time!
lilrez
Nice
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I switched and the extra height was unnoticeable to me because it was softer. And because it was softer it seemed like a marshmallow under me and just floated around. Didn’t seem to have support where I could shift my weight a little and Sobel to push or pull as easily because it was so soft. And actually felt to squishy even on rough trails. I went back to stock.
lilrez
Dam. Im a taller guy and would like to find something an inch or two taller and that still looks good. I the old days we would build an wooden box under the indy seat to raise it up
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I’m 6’5” and the stocker is more comfortable. Remember on trail it’s a balance between comfort and being able to maintain low cg. Stock seems to do that best for me
lilrez
Yep. Me too and 3 feet of it from my knee to ankle. Lol. . For short rip trips stock seat good. For long long days of riding id like it taller.
Not that i always agree with the snowtrax boys but they also commented on the 19 seat hight in comparison to the doo and poo and wished it higher
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Love mine.....Higher and very cushy. Not too soft at all IMO, and very much like the older XS doo seats which were ultra cushy.
I will say when the design for me is perfect for aggressive trail riding, since the front does slope down to a very similar height to trail seat, so you can scooch up, get low and rail the twisties...or scooch back and raise up/back to cruise.
Also one of the biggest reasons for me was to gain tunnel length on my short 129" tunnel, this allows for my LinQ bag to open nicely, while trail seat 'tail' was too long.
Dan
Dan
lilrez
Thanks Dan. Ive wanted the cross country seat for some time. Not sure what the yam prices were but the cat one is like 666.95
Wow.. just noticed the edges of your running boards are same as the stronger ones found on the RR> .. I didn't know yam had that option on the 50th...cool.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yeah its very expensive! You can buy the foam and cover and its somewhat cheaper.Thanks Dan. Ive wanted the cross country seat for some time. Not sure what the yam prices were but the cat one is like 666.95
lilrez
True.... cover is like 370....but if i owned an upholstery shop i wouldn't touch it for under 250 and the end result would look like crap anyways.........well unless they added some green flames or something lolYeah its very expensive! You can buy the foam and cover and its somewhat cheaper.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
How much is the mountain foam and cover ? Cdn dollar?Yeah its very expensive! You can buy the foam and cover and its somewhat cheaper.
lilrez
https://www.blwpartsfiche.com/ is a good resource for cats.. Im not sure of a Canadian site for yam but prices often same
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I have one season on a stock seat and one on the mountain seat. I'm 6' and 170 lbs and I like the mountain seat better because it's a little slimmer and a little taller.
