WINDER1987
hi everyone I'm getting ready to pull the trigger on the racewerx transfer blocks but just checking before I order it anyone else has seen anything better out or in the making and what's your opinion on the racewerx? Thanks
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
I been on this chassis for the last 6 years and have always just taken the plastic blocks out and ran with just the tube installed.
Did you see this thread?
http://ty4stroke.com/threads/removing-transfer-blocks.145776/page-3
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Save your money, just remove the blocks...hi everyone I'm getting ready to pull the trigger on the racewerx transfer blocks but just checking before I order it anyone else has seen anything better out or in the making and what's your opinion on the racewerx? Thanks
WINDER1987
Yes I did just seeing if anything new was outDid you see this thread?
from what others said the racewerx adjusts to more transfer than with the blocks removed is this true or it just the ease of fast adjustments?Save your money, just remove the blocks...
DMCTurbo
- Nov 12, 2005
That I can't answer...Yes I did just seeing if anything new was out
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Loosen straps to the last hole, it makes more difference. Blocks removed, bar left in place.
I think depending on rear wheel size, you could move the rear bar back closer to wheels...would need to drill two new holes. Not sure it would make huge difference though, not much room before wheels.
Dan
Dan
Maybe somebody that has the racewerx can measure the radius, center too outside of the block on the 1st setting and compare to the stock bar. I just don't see gaining anything there though because the stock bar has a flat side on it which I articulated facing forward so it makes contact there and it is just slightly larger in diameter than the shaft itself.
The only reason I would go with the Racewerx is to quickly adjust for more transfer if the conditions are more loose snow than hard pack.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
This wednesday or friday i plan on removing my Racewerx adjuster & taking measurements compared to stock. I'll post results...
- Sauk Prairie, WI
- www.ty4stroke.com
I loosened my limiter to the last hole, tightened center shock about 3/4" and removed the blocks and can tell you it transfers. I wouldn't want it transferring anymore than it does.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Did you find tightening the Centre shock helped with the heavy steering? Also by stiffening the Centre shock did it ride ok? Not too rough?I loosened my limiter to the last hole, tightened center shock about 3/4" and removed the blocks and can tell you it transfers. I wouldn't want it transferring anymore than it does.
- Sauk Prairie, WI
- www.ty4stroke.com
Yes, it works great. Takes some pressure off the skis, makes it transfer better but am sure it will effect ride some.Did you find tightening the Centre shock helped with the heavy steering? Also by stiffening the Centre shock did it ride ok? Not too rough?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I just put a different spring in my LTX-SE.. (have not rode sled with it yet)
Its apparently rated at 135/265 instead of >>>>>> 90/260 I believe to be stock on the SE.
http://www.raptorshocks.com/store/products/Triple-Rate-Springs-(Front-Track).html
Not sure this even applies to the LE but IMO the initial sit in or sag on the stock spring(SE) is a TOUCH to light which is causing heavy ski steer.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
removing the block with the rod in works...but ...hitting the rod will jack up the paint on those pads ...also...when Im done on the lake...and hitting a winding trail...I just turn the racewerx to where I want it and im there...and removing the rod altogether...to me...too much transfer to corner to corner burn..
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yours is a 129? I cant recall.I loosened my limiter to the last hole, tightened center shock about 3/4" and removed the blocks and can tell you it transfers. I wouldn't want it transferring anymore than it does.
I wonder if I put the blocks back in now, with straps at very last hole now...would it be good still?
It works better now with blocks out and straps loosest for sure. But personally would not like metal to metal contact if sled was my own.
I will come up with some sort of pad, maybe just a piece of abs tubing over the bare rod.
