SledFreak
- Feb 7, 2005
- Ontario. Canada
I would not mine getting the header tune... Just not convinced the cracking is fixed and I believe the sled requires more maintenance. Also gives off way more heat. I hear the header gives 30more hp in the mid range over pm 300 tune on less psi...No, boost pressures should be very close. Power will likely come on sooner and harder and if your trying to attain bigger speeds of 125+ i think the pm will help there. The header tune will make same power at lower boost pressure. I believe 270 header pm tune runs around 15psi vs the 17-17.5 of stock manifold.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
To be honest, out of several hundred hurricane headers sold, there has NEVER been a header tube crack. We have however seen a couple of flex joints crack but the reality is that the flex joint still didn’t leak when the bellows cracked due to the internal joint design.
Therefore when we sum up all hurricane high clearance headers ever built, there has never been a failure in the header to create an exhaust leak
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Well thats the most important part. The inconvenience of a crack AND leaking can ruin a ride or lead to something worse. Once youve done a header install once or twice it really doesnt take too long to swap out. What scares people away is the possibility of being far from home and having a failure/leak. If under most circumstances that isnt the case with the hurricane header then thats the ticket right there.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Besides that how much of a gain and where are the gains of the header? Is it mid, bottom end?To be honest, out of several hundred hurricane headers sold, there has NEVER been a header tube crack. We have however seen a couple of flex joints crack but the reality is that the flex joint still didn’t leak when the bellows cracked due to the internal joint design.
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
Header works better with pump gas but around 5 hp more in race gas situation.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
300hp ss header tune is only making 17 pounds of boost. The header tunes make more power with less boost.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I don't have a header, and have nothing against anyone that does.. Is the chance of burning up and ruining your sled or worse worth it? For slightly less boost for the power level? Personally I think a bigger intercooler hanging off the front will give a greater reliable gain and hold intake temps way down on long pulls.. Plus it wont break, and its cheaper. I have been following these headers for awhile now and the posts I see about cracks and failures is not that convincing me to jump..
Would like to hear thoughts on which flex is better. Braided, or the factory style?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Run both intercooler and header with no issues.I don't have a header, and have nothing against anyone that does.. Is the chance of burning up and ruining your sled or worse worth it? For slightly less boost for the power level? Personally I think a bigger intercooler hanging off the front will give a greater reliable gain and hold intake temps way down on long pulls.. Plus it wont break, and its cheaper. I have been following these headers for awhile now and the posts I see about cracks and failures is not that convincing me to jump..
Don't wrap the header.
Really like the corner to corner performance with the Hurricane super spool header, o2 module tunes.
It will lift the front end at will over any trail junk.
Is the flex a different style than the factory one. Mine cracked, I knew it was leaking because I could hear it.To be honest, out of several hundred hurricane headers sold, there has NEVER been a header tube crack. We have however seen a couple of flex joints crack but the reality is that the flex joint still didn’t leak when the bellows cracked due to the internal joint design.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
stgdz
- Mar 27, 2021
- Buffalo MN
So for 91octane users we are still limited to 270hp even with header and pm tunes.
Fleecer
- Jun 13, 2014
- 2019 SRX
The big intercooler will permit you to run the SAME horsepower longer as it keeps iats in check. IMO the big intercooler hanging off the front says, "Hey look at me, I have a big turbo with 500hp." Then you get smoked by a sled running Powertrail and everyone laughs at you.
A header allows more power with less boost on lower octane, which are the advantages. All things being equal, a sled with a header will outrun a sled without it. The disadvantages are as you state; They are pricy and there is a risk of burnt bellow, possibly sled burning down etc.
My stock flex cracked. Half way around on one of the outside rings. I noticed it the day before I was leaving for Quebec. Welded the ring solid and it held for 1200kms.@74Nitro what manufacturer header you running or are you talking about the stock pipe cracking?
Looking to maybe fix it with a new flex or braided piece instead of buying new assembly.
Only 270.....So for 91octane users we are still limited to 270hp even with header and pm tunes.
(One of my eyes is winking)
- 17K
- 12K
- 8K
