DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Has anyone had this happen?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Seen it just in the outer layer of tunnel. Stop drill holes and add plate to inside that all three bolts go thru.
DMCTurbo
- Nov 12, 2005
Ya its just in the outer layer. My son's buddy is a welder, he said he can fixer up.
RAMSOMAIR
You are just putting waaaay too much stress on that old girl lol.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The way the tunnel is designed in that area two pieces come together with a crease for the brake caliper mount. With the flex in that area the crease will crack over time. The sharp edge should be lower in the tunnel before it gets to the caliper mount.
stgdz
- Mar 27, 2021
- Buffalo MN
Not sure on aluminum, most of the welders that I talk with say welding aluminum will weaken it.Ya its just in the outer layer. My son's buddy is a welder, he said he can fixer up.
Is this crack near the brake caliper?
DMCTurbo
- Nov 12, 2005
Ya it is.Not sure on aluminum, most of the welders that I talk with say welding aluminum will weaken it.
earthling
Brazing a plate over the existing area is an option. Brazing is very strong and does not cause the aluminum to loose as much of its temper as you are not heating it up as much as you would for a weld. The plate will also help you distribute the load. On the other hand, a decent weld is better than a crack/split even if you are ultimately losing some strength right in the weld area.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Instead of welding maybe drilling some holes in steel plate securing it with cherry rivets with steel washers behind them would work best. We used that method on the old chassis ( pre procross ) and it worked pretty well.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The brake caliper sits right there so building it up higher is not an option.Brazing a plate over the existing area is an option. Brazing is very strong and does not cause the aluminum to loose as much of its temper as you are not heating it up as much as you would for a weld. The plate will also help you distribute the load. On the other hand, a decent weld is better than a crack/split even if you are ultimately losing some strength right in the weld area.
$400 plus fasteners for a new center section of tunnel.
The center section of tunnel rips apart where it is riveted to the top of the heat exchanger also where the crossshaft mounts they crack there also.
So we know of 3 different areas to look for issues.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
earthling
Forgot where that sits relative to the caliper, you are right.The brake caliper sits right there so building it up higher is not an option.
I thought for that center section over the heat exchanger you put in that plate from craigwsrx? I have one sitting here but the sled is still parked from last year waiting for all the other projects to finish.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Yes I installed the plate from craigwsrx and also installed tunnel saver plates from BOP for the front crossshaft mount.
Looks like damage from flying debris
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Did you have a BOP driveshaft saver? Travis has a video on YouTube saying that you must not over tighten it because it can cause the rotor to not have free play which can cause tunnel flex.... Just a thought.
