Turboflash
- Mar 18, 2019
- Southern MN
If you're using BOP shaft saver, KnappAttack posted on how to get it centered and true so shaft spins concentric and doesn't cause tunnel to flex as it turns.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Is this the post you are referring to?If you're using BOP shaft saver, KnappAttack posted on how to get it centered and true so shaft spins concentric and doesn't cause tunnel to flex as it turns.
Post in thread 'Serious brake fade or lack of brakes??' https://ty4stroke.com/threads/serious-brake-fade-or-lack-of-brakes.159142/post-1509959
Turboflash
- Mar 18, 2019
- Southern MN
No. I'll do a search and find it.
Turboflash
- Mar 18, 2019
- Southern MN
Here it is:Is this the post you are referring to?
Barn of Parts Driveshaft Saver....Bearing Lock
I had new shaft and new bearing snk bench tested exactly like bop did .001” difference in fit and started to lock down at 60lbs. I’m taking apart this weekend to see if spun give you updates. Any updates on this? Didn’t see any unless I missed it.
ty4stroke.com
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I run yhe BOP driveshaft saver but my rotor has always had lots of free play.Did you have a BOP driveshaft saver? Travis has a video on YouTube saying that you must not over tighten it because it can cause the rotor to not have free play which can cause tunnel flex.... Just a thought.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Free play of the disc does not dictate wether or not if the bearing tightened down on the shaft crooked. I’d bet with certainty you’ve been running a crooked bearing on the shaft and flexing the tunnel. Nothing else explains the crack you have. Flexing the tunnel with a crooked bearing would explain the cracking you have. When things flex they break, it’s that simple.
You need to make certain the bearing gets nomilized on the shaft to prevent flex. It needs rotated many revolutions as the wedge gets tightened up to prevent a crooked bearing on the shaft and this flexing. I also use a dial indicator to make certain it’s not crooked on the shaft and flexing the tunnel.
