sledheadgeorge
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Judging by your pic that is a 129 or 137.
Since this tunnel is used in all models the holes are drilled to accommodate all: 129/137/142/153/162
And it varies by year also.
This is up to 18
https://ty4stroke.com/threads/why-a...ting-holes-for-the-skid-in-the-tunnel.150243/
Here is 2020 with ARCS
This is up to 18
sledheadgeorge
That's very interesting on the lower mount for the arcs. I ride the mountains couple times a year where my son lives and see quite a few skids lowered on the rear skid mount bracket. I've been told by a few who have built custom machines, a lowered skid rear point helps move out the snow better.And it varies by year also.
This is up to 18
Makes sense. I am having a hard time keeping up with the changes Cat makes to suspension every year. Need to make time to make a spreadsheet.That's very interesting on the lower mount for the arcs. I ride the mountains couple times a year where my son lives and see quite a few skids lowered on the rear skid mount bracket. I've been told by a few who have built custom machines, a lowered skid rear point helps move out the snow better.
swampcat
Strange, because Cat for 2020 with the same ARCS front, mounts their 137 skid in the UPPER rear hole . They also still use a smaller diameter upper carrier wheel . Youre right, hard to keep up on this stuff.Makes sense. I am having a hard time keeping up with the changes Cat makes to suspension every year. Need to make time to make a spreadsheet.
Really !Strange, because Cat for 2020 with the same ARCS front, mounts their 137 skid in the UPPER rear hole . They also still use a smaller diameter upper carrier wheel . Youre right, hard to keep up on this stuff.
swampcat
Next time your over at T.A., see whats going on. Like you said, hard to keep up on this stuff.
Turboflash
- Mar 18, 2019
- Southern MN
Upper wheels in Cat skid are: 2017 thru 2019 use 3604-901 = 6.38" diameter. 2020 uses 3604-264 = 7.12" diameter.
swampcat
Thanks for the info. So much for that theory. 2020 Winder looks to be 7.12 also.Upper wheels in Cat skid are: 2017 thru 2019 use 3604-901 = 6.38" diameter. 2020 uses 3604-264 = 7.12" diameter.
- 8K
