Tunnel sticker removal
Tinman1944
Rockford, Illinois
What is the easiest way to remove stickers on the tunnel of my 07 apex attak? The tunnel is painted black and do not want to hurt the paint.
Thanks :yam:
Goo b gone.... there are several things at your local auto parts store that will remove the adhesive once you peel the sticker away.
Just use a little gasoline on a rag works great just as good as goo gone.
WD40 works great, lubes as you rub so no scratching and its cheap use on cars, bikes and sleds all the time.
Heat the decals up with a blow dryer or heat gun first....remove the sticker. Then use the above methods to get off the adhesive residue.
--Steve (O.C.)
