sheetwright
I was wondering if anyone knows of somewhere to buy a turbo blanket for the IHI RHF5 Turbo on the Sidewinder? Some thing similar to this?
https://www.ptpturboblankets.com/collections/ihi
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
interesting
Buckeye
- Lakes Region, NH
Do a search for dei turbo heat blanket on amazon. There are many to choose from
sheetwright
Any idea which blanket it would be comparable too? (T3,T4,T6,ETC.)Do a search for dei turbo heat blanket on amazon. There are many to choose from
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
This is what you are looking for. A T3 unit is a little tight, I'd recommend the T4 setup. If you go the DEI direction, I can shoot pricing to you as we are a DEI dealer. I have used the PTP units as well.
http://designengineering.com/ultra-47-turbo-shield-custom-fit-turbo-blanket/
https://www.ptpturboblankets.com/collections/t3-t4/products/ptp-t3-t4-turbo-blanket-lava-1
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
What r the benefits?This is what you are looking for. A T3 unit is a little tight, I'd recommend the T4 setup. If you go the DEI direction, I can shoot pricing to you as we are a DEI dealer. I have used the PTP units as well.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Less underhood heat.
upnumber6
- Jan 3, 2016
- Winnipeg
- 2007 apex rtx, 2011 apex se
T
Also Theory is more heat you can keep in your turbo the more efficient it isWhat r the benefits?
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
http://www.superstreetonline.com/how-to/engine/impp-1103-turbocharger-heat-shielding-fact-fiction/
Doesn't do much according to this article, obviously not an apples to apples comparison tho, car vs a sled.
- 17K
