View attachment 104283View attachment 104284 Hey guys, I'm buttoning up the install but I'm wondering what goes to this actuator off the turbo? Also what's this crazy shaped hose?
It looks like you have a MPI Stage 1 kit (intercooled) or you have the MPI intercooler upgrade for your Spring Power Surge Yamaha/MPI turbo kit.
The nipple on the intake housing you have posted the photo of is the blow off valve assembly that is on the turbo, this will need to be hooked up to your vacuum hose that you installed on the throttle bodies already (this line will also get a tee fitting and run a hose to the blow off valve assembly on the front of the intercooler as well, be sure to zip tie both hoses onto the fittings).
The second hose (1" ID hose) is for the engine to the thermostat housing.
