mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
TANK SHOULD never be higher than injectors.mbarryracing said:slymax said:No, I got it exactly like the instructions say. I have a vented tank where the radiator used to be, I have the pump down in the nose and I have the 3 nozzles above the pump in the intercooler.![]()
Umm... Your reservoir / tank is higher than the nozzles, I recall that fluid seeks it's own level, so this sounds like it's flowing past the pump. I remember reading in the directions on a snow performance kit where it mentioned something about checkvalves if the tank is higher than the nozzles?
slymax
I was told that the pump would not allow fluid to run through till it was activated....that would appear to be incorrect.
snowy1
I have my pump mounted on the clutch gaurd, the tank is above it where the head light normally would be and I have not had a problems, works great.
Skydog
Mount it higher just run a shut off selinod that is what i did.
Skydog
Skydog
slymax
I have my tank mounted where the radiator used to be which is about 1" above my intercooler and it is definitely a problem. I don't think you can run stock compression either, although it sure runs strong. Will have to tear down and look and see what damage etc and decide from there.
