SuperDave
I am building these kits and have teamed up with Yamaha dealer in Salmon Arm BC Canada. The kits sell for $6000. canadian and have got 10 done now and are very clean and simple to install because we will have jetting and clutching with it. Give Julian a call at 250-804-4334 cause he is selling them and i only building them.
We were at grass drags in Merritt BC with a Turbo with 159 finger track and run 13lbs boost!! yikes it goes good running with 1400cc PSI with nitoris and pulls harder then the nit, 1400 on top end real bad!!http://www.powderlites.com
thebest
superdave do you change your head gasket for the kit or run stock gasket. thebest.
SuperDave
head gasket for Turbo?
yes kit comes with head gasket in it and we have run Turbo last week end up against big 1600cc PSI motor plus had nitirus on it.
The PSI makes about 260 HP plus when he hits the button it really comes out of the hole fast but RX1 Turbo still gets it in the end on grass drags in Merritt BC, Canada
What a ride!! we had run it at 13lbs boost and heavyest weights we had to keep her off the rpm limiter.
True Blue
Superdave,
can you post a picture of your kit befor install and after install?
I am very interested. Canadian Dealer +++ way to go.
TB
TB
SuperDave
pictures of Turbo kits
here r some more + tunnel kits we are building for light weight and 159"
Quicksilver
Looks Sweet. Is that an ekholm tunnel ? Are you offering that tunnel with a dropped & rolled chaincase? If so what dimensions. Do your tunnel kits come in shorter lengths? How many canuck bucks FOB with the rear exchanger? I an located in Sask.
