madmann1
anyone have any clutching suggestions?
rear mount gt2560 turbo
14-16 lbs boost
elevation 2200ft
162 2.25 act track
whal 7 tooth drivers 6.55"
19 - 40 tooth gearing
act roller secondary clutch, lime green spring, 55/53 helix, rock rollers
white pink white yammi primary spring
engages low at 2700rpm shifts out at 8500rpm
wont pull full rpm in the deep snow(dont smell burning belt)
stock primary white pink white spring, 15.8 rollers engaging at 2800rpm
primary weights are aftermarket just dont know who makes them
weight 69g total with one screw in thew tip
ride mostly flatland want mostly bottom end pull for boondocking NOT LAKE RACING. not super agressive rider weighing in around 200lbs
hook me up you masterminds
14-16 lbs boost
elevation 2200ft
162 2.25 act track
Turk
Tech Advisor
I set one up a few years ago with a simmons cpr kit with a 2554 running 10 pounds boost.
I used supertips loaded to 66 grams with a 48/44 helix. Your gonna need a lot more but this will point you in the right direction.
What are you pulling for rpm,s right now with your set up otherwise no way no how can anyone help you.
madmann1
not sure what the rpm,s max out at, too scared to look down.
I think the max is around 8600rpm which I should be able to adjust
with raising or lowering the primary spring rate on the top #.
last time I was out (last year) it was struggling to pull the high rpm's
in deep powder.
still repairing top shaft brg.
in deep powder.
madmann1
seriously no tvector guys willing to share there secrets, what the fudge?
dirk_03
Turbo Vector
I used 8bu-10s fully loaded. the smaller diameter rollers. I think they are a 14.5mm and if memory serves me right a blue/pink yamaha primary spring. I used a purple EPI spring in the secondary with a twist of i think 0-1. And a shockwave helix. That was last year with my turbo vector with a 162 camo extreme. It pulled rpms perfect.
This year I am running the same setup in the primary with a team secondary with a black/lime spring with a 44degree helix and it pulls proper rpm as well. Clutches stay cool, only slightly warm to the touch.
You wanna shoot for 8400 on the tvec. For it to do 8400 climbing it may overrev slightly on the trail. It is easy enough to just not allow it to overrev on the trail though.
madmann1
what kind of boost were you running at what elevation?
any idea of what your gearing is?
thanks for the help
thanks for the help
dirk_03
madmann1 said:what kind of boost were you running at what elevation?
thanks for the help
Elevation was anywhere from 6500-10000 ft.
Can't remember what my gearing was at last year on the yamaha chassis. but this year with the ski doo it is at 19/43. I know because I exploded a chain out in a ravine this past weekend.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
madmann1 said:anyone have any clutching suggestions?
14-16 lbs boost
elevation 2200ft
162 2.25 act track
stock primary white pink white spring, 15.8 rollers engaging at 3800rpm
Wow the clutching could not be more Wrong.
I make clutch kits and tune clutches all over the world on boosted sleds from sea level to the highest elevations.
Call me
Ted.
