i know it's not ideall but can you ride two up on an rx1 without sending the studs into anything? I don't want to damage it but will need to use it two up in a few weeks and am concerned because how low it sits already.
you need to set the suspension for the 2 up weight for the best results. i would set it up for 2 up with the fra on full hard with the transfer set at 50/50 or 60/40. you might be able to turn the fra down to medium or soft for solo riding without changing any other settings.
AftonJay
- Oct 23, 2012
- Northern Michigan
- 2005 Warrior, 2009 Nytro XTX and Arctic cat puma for the kids
- Afton Mi
Maybe tighten the track as well so you don't get much "ballooning" at speed. And not to get to personal but what are you talking about combined weight?
