Woody255
Hello all, any significant updates done to the 21 SRX compared to previous years, aside from the chaincase sightglass being removed?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I believe the upper bushing was updated last year, haven't seen any reports as how that is holding up.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
Wore out 2 upper gears last season on my 21 srx.. 6500km. Will be ordering the dmc gear soon. Also have my driveshaft out right now and have alot of wear on it as well. Wish I would have installed a driveshaft saver.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Warranty itWore out 2 upper gears last season on my 21 srx.. 6500km. Will be ordering the dmc gear soon. Also have my driveshaft out right now and have alot of wear on it as well. Wish I would have installed a driveshaft saver.
Fast
- Sep 25, 2018
Curious what chain tension were you running?Wore out 2 upper gears last season on my 21 srx.. 6500km. Will be ordering the dmc gear soon. Also have my driveshaft out right now and have alot of wear on it as well. Wish I would have installed a driveshaft saver.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
2012 Apex xtx
Ya working on it.Warranty it
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
2012 Apex xtx
Was 1 1/4 to 1 1/2 turns out. Any more then that and the chain slap hits the case. Using amsoil chaincase oil. 16oz checking tension every trip and changing it every 2k.Curious what chain tension were you running?
No matter what brand of oil you run, my suggestion is to run something that is GL-5 rated in any 4stroke chain case (turbo or not). I tried the single bottle of Amsoil "chain case" oil and that's when I started to see accelerated wear. I will run that lighter weight oil in any 2stroke or diamond drive system but not a 4stroke. I'm not saying that wear does not occur or that I've found a silver bullet, after all this chain case is what it is. I try to set up for reliability. This is a long drawn out topic so I'm only posting about my findings.
