chocking41
- Nov 20, 2023
- Minnesota
- 2011 Yamaha Nytro
Sorry if this is an obvious answer....Is the process for removing and reinstalling the A arm upper ball joint on the sled without a press ( using a socket and long bolt ), the same as the lower ball joint ? Any special tips. Had to get a new A arm as the top hole was really egged out. Figure i just as well put a new ball joint in .
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
They both are bolted in place. There's absolutely no need of a press of any kind.
