Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
I pulled the skid out of my Apex...Just re greasing the idler wheels...(way to go Yamaha) ..Anyway, my two upper idler wheels have the rubber starting to split in places on the top of the wheels...how do I get them off the shaft? Are they just pushed on the shaft and are now stuck or do I need a big #*$&@ puller...?
vice108
You need a puller to get that bearing off. Its pressed on tight.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Put the skid on its side on a work table, have the shaft hang over the end on the table. Use a rubber hammer and hit the shaft from the top. It will push the bearing off the shaft. Then flip the skid over and do it to the other side.
Kaz
You don't need a puller, just tap the end of the shaft with a mallet and the bearing/wheel will come off, there installed with a light interference fit.
Once you get one wheel off do the other side with the axle in the suspension.
Kaz
Kaz
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
wheels
Thanks for the ideas!!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Screw the bolt back into the shaft 1/2 way and then use a rubber hammer to tap on the bolt, shaft should slide off bearing.
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
got the two wheels off....simple...stick bolt in end of shaft ...give a wack and watch them fall off..replace bearings and install
