Black7
- Mar 23, 2013
- Michigan
- 2015 SR Viper X-TX
2016 SR Viper S-TX 137 DX
Very nice. I will miss your write ups on your MTX.
I went after a Nytro XTX
last Winter, then started to lean towards the Viper XTX
, and bought a leftover 2013 Phazer MTX in the end. Yeah, it was weird.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Maybe there will be more reports here because I still own the Phazer
Malibu
In my opinium,the best yamaha series ever made ........NYTRO TTX-APEX TTX .Congratz .Now it's done. Bought the Nytro TTX today. Öhlin shocks equipped in the front and in the skid.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Now my garage looks like this.
I'm still working on the garage itself. I will change the floor later on and do some other stuff. But I like it here to work on my sleds. Even installed a big screen for showing snowmobile movies on while working =)
Did some rebuilding to the Phazer today. My wife will have that sled now, so I am making it so stable as it can be. So I moved the idlers wheel in the back out to the original position and added a fourth wheel in the rear. I know, it's three different kinds of wheels in a set of four. As long you keep the speed up, no one will notice =)
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Ordered some bearings and the OFT bushings for the steering. The Phazer steering is so sloppy.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Yeah, I checked out a new Phazer in the showroom once and it had sloppier steering than ours with the bushings, UpBushman's kit and better joints.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
This is what I ordered:
and the bearing I have posted before:
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I also added some new ice scratchers. I had some generic steel spring scratchers before, but I forgot them a couple of times going in reverse. So they are history.
So I got these reverse compatible ones.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Powder coated the parking brake lever red today. The wife wants to run a red, black and white theme on the sled. We started with the parking brake lever =)
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Got the package with the bushing and bearings yesterday. Started to tear the steering down last night.
I didn't know that the bearings were Yamaha original. Got a plastic bag with a nice instruction sheet that is easy to follow.
Pressed the bearing in to the steering part with a workshop press. Keep it straight and just press and it won't go wrong.
But the Phazer has the worst steering. Some play in every linkage there is on this sled. But I am tightening everything up nice now, so it will be better. But I think I have to change all the ball joints too. They are just to sloppy.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Took the sled apart a bit. Removed the tank to get the OFT steering block in place.
It's a tight fit with the cables coming down thru where the block goes.
And the bearings in place.
The steering is much much better now with all the tightening made at all the joints and linkage. I think I will buy the outer ball joints at the spindles next week and change them. Because they have too much play I think.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
What ski shocks should I get?
I have found two different one to chose from. One is Engans and the other one is Fox Float 3. It's about the same price for them both, so that is not a deal breaker.
Any suggestions?
Any suggestions?
laxdad
- Oct 7, 2014
- Snohomish, WA
- Phazer MTX
Weldion, im very impressed. Im a machinist by trade and your work makes me smile. Heck it almost makes me want to fly to sweden to come ride with you.
What others plans are you doing to the MTX to stabilize it for your wife?
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
Regarding the shocks, is there any way you can find out the weight of each? Personally, I would lean towards the Float as it doesn't have the 'extra' weight of the external spring, but it's hard to say for sure without knowing what each of them weigh. If they are similar in performance and price, I would probably go with whichever one would bring more weight savings to the sled.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
You are welcome overWeldion, im very impressed. Im a machinist by trade and your work makes me smile. Heck it almost makes me want to fly to sweden to come ride with you.
We have a guest room, sauna and snow.
I have no other plans. Maybe move the skis to the outer position.
