Vector LTX torque specs (2010)
yam429
Saint Michael, MN
2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
LOCATION
Saint Michael
I need the torque specs for the rear suspension mounting bolts to tunnel. Rear axle torque spec would be helpful too.
Although your inquiring about a 10 Vector LTX, I would venture to say the torques would be the same as my 08 Apex LTX. They are as follows:
Suspension Front = 43ft/lb
Suspension Rear = 61ft/lb
Rear Axle = 54ft/lb
Thanks. When you refer to suspension front I take it that’s the front mounting bolt on the rear suspension? Any chance you know the torque spec for the upper rear bogie wheels that mount to the tunnel?
Yes, the suspension bolt in the front by the footwell.
As for that the upper rear axle with the two bogie wheels, it has the same torque as the rear suspension bolt; 61ft/lb
Great, thank you so much!
