ontarioyamaha
- Mar 26, 2017
- Port Perry, Ontario
- 2010 Vector ltx GT
2010 MXZ X 1200
- Port Perry
I have reviewed all the tutorials and suggestions regarding the installation of a water temp gauge. I plan to install on the vertical coolant line. I cannot seem to find a consensus on the inner diameter. I see people have used everything from 22 to 26mm. Once person was saying 26 was difficult to get in and suggested a 25.
Royal Distributing has a 22 and then it jumps to 26mm
Has anyone installed on the 1049 engine and if so what size will work best?
I have but its after I installed a Turbo or Super Charger and tapped into the port on the back of the motor fitting that was provided. I would think it the fitting will go into the hose and you put some good SS worm clamps it will go.
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
I installed temp gauge on my nytro and put the T in the coolant line above the engine. I used 26mm adapter, worked fine.
Hope this helps.
Hope this helps.
ontarioyamaha
- Mar 26, 2017
2010 MXZ X 1200
- Port Perry
I cut the vertical line today and the koso 26mm diameter adapter works mint. Nice snug fit and very easy to insert
Picked up at Royal distributing
26mm blue koso
26mm blue koso
radianguy
- Jan 1, 2007
Major brain fart, I installed a temp gauge on my vector over the summer, totally forgot about it until I just read your last post. Should have known it was 26mm same as my nytro. Duh!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
26mm blue koso
I've seen them in the vertical line, but I was never 100% certain that was the best spot. The vertical line is the circulation loop when the thermostat is closed. Once the thermostat opens I believe flow through the vertical line is minimal as the coolant flow is directed to the radiator and then into running board loop.
ontarioyamaha
- Mar 26, 2017
2010 MXZ X 1200
- Port Perry
I considered that as well. That said, The factory sender is located in the same loop south of the thermostat. The coolant from the rad and heat exchanger would enter the engine via the same vertical line would it not?
- 32K
