Tilly17
- Mar 8, 2022
- Haliburton
- 2016 SR Viper LTX-LE
Anybody have any comments about what I think I feel as a vibration at about 30 - 40 mph. Seems to be rear of sled and not engine. Just got this used 2016 Viper LTX with only 3,000 miles and with an aftermarket track with 1.6” lugs. is it possible the longer lugs are the cause? The track was removed and a 4th wheel kit installed by previous owner before last season. I can’t really say if the vibration disappears at higher speeds.
po might have installed new slides and you are feeling the clips hitting as it wears in.
smokingcrater
Check all your idler bearings to see if any are failing. At least in my experience I usually have at least one bad one by 3k miles.
And change the belt. Been fooled by a flat spotted belt more than once.
- 40K
