kinger
I have what feels like the driver tips hitting the rails or track funny when doing side hills or at full compression.
Track is straight, no rub marks can be seen. Anyone else notice something like this?
Thanks.
Thanks.
alpineviper
- Aug 24, 2014
- Alpine Turbo Viper
are your limiter strap bolts coming into contact with the drive lugs on the inside of the track? mine were. there is an update to turn em around
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
I have the same thing happening. I'm not aware of an update to turn around the bolts.
alpineviper
- Aug 24, 2014
its a arctic cat update i think
Joshua
- Apr 14, 2010
- Newfoundland
Any pictures? Or a copy of the update from AC
alpineviper
- Aug 24, 2014
no...my dealer sells both and he told me.. some people on snowest also mentioned it.
Joshua
- Apr 14, 2010
- Newfoundland
So, how should the bolt look like when changed?
alpineviper
- Aug 24, 2014
they took mine out and cut them....they are way to long....then replaced the opposite way.
kinger
Yes I see some wear on the inside of the drivers on the introvert tooth now. I’ll check the limiter strap bolts thanks for the suggestion!!
alpineviper
- Aug 24, 2014
not the drivers.....it hits the drive lugs on the track. The rubber nubs on the inside of track.
customnytromtx69
Check your rail tips and front of your sliders , mine was hitting the drivers and wore out the rail tips and the slides right at the bolt that bolts them to the skid . Replaced them last season at the very end of the season and then had to replace them again midway through this season
- 40K
