bmazbnytro
I was wondering if anyone could help me out that has a LTX. I’m installing a 2018 LTX 137” skid in my Nytro. I’ve looked and can’t find any info on doing this, many have done the 141 or mountain set ups. I’m looking for the distance from front mounting hole to rear mounting hole. I can measure the skids but I just want to be safe as the Nytro has a little bit of preload on the rear to line up the holes and the Viper has the slide in front arm where the mounting shaft is bolted in and the front arm just slides over it. I want to make sure this doesn’t fall out or off while riding.
Thanks for any help!!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I will try and measure an ltx tunnel today for you.
bmazbnytro
Greatly appreciated!!I will try and measure an ltx tunnel today for you.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I measured 30.5” center to center between holes
bmazbnytro
Thank you very much. It looks like there is about 3/4” of preload after measuring the skid.
Tod
Need any help— I want to do this too.... Tod
bmazbnytro
Tod,
What kind of help are you looking for?
Tod
Please post pics of your install—- I would like to do this also on my 2009 nytro xtx—- I was offering to help you if u needed an extra hand—- lm in Decatur Indiana— TodTod,
bmazbnytro
Just a little update. I started the project yesterday and ran into a hiccup. My Nytro had already been converted to a 137” via rail extensions. I went to start the 137” Viper install and sat the skids side by side and pulled some measurements, seems like it will fit with no issues. Upon installing, and putting the skid in I realize my track is not long enough. Not sure why? I assumed 137” meant 137” on the track. The rear viper wheels are 8.5” and the upper skid wheels are 6” I think, can’t remember exactly. The stock rear wheels are 7” and uppers are 5”. I believe this is where my track length is being compromised. My question is this. If I move the mounting holes 1” forward on the tunnel, what kind of effect would it have on the balance of the skid and sled? Would it still work properly? Would a 2015 Viper track bolt right in or would I need different drivers if I have to go this route.
bmazbnytro
Grizztracks, sorry buddy, any insight on this?
