yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
alright stuuded riders, I have 144 gold diggers on there way and will be putting them down the center. What carbides are you running and how are they working for you? Debating on 6" slim jims, 6" shaper dollys on stock skis, Curve xs skis, or c&a razors.
Havent open trails up around here yet so hoping to get some advice form guys who have been avle to ride on the trails.
powerguy1 said:Dealer recommended 6" woody's trailblazer carbides with 144 studs. Said that the arctic cats with this skid don't have darting issues.
Went out today on a rail bed trail and sled darted like crazy. Felt a pull whenever I crossed a ski track. The faster I went the less darting . Have stud boy dual 6" carbides on order.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Using 6" Stud Boy Duallys with 96 1.375 studs down the center. Very very little darting, usually none at all.
Curve Industries
TY Advertiser
- Jan 20, 2008
- Waterville, NY
- www.curveindustries.com
Curve riders - go with a 6" Shaper or round bar on your Vipers.
- Sean
- Sean
TestMaster said:Using 6" Stud Boy Duallys with 96 1.375 studs down the center. Very very little darting, usually none at all.
How do you have your suspension set?
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
I have base LTX so spring front end. Rear set to #2 setting but I have accessory adjuster that has 4 positions vs three on stock adjuster.powerguy1 said:TestMaster said:Using 6" Stud Boy Duallys with 96 1.375 studs down the center. Very very little darting, usually none at all.
Hard to say front setting because it's spring not air. Would say front is factory setting which I will adjust with more stiffness. As suspension breaks in front is definitely too soft, bottoms on moderate-large bumps especially if square edged. If you would like I will measure spring length and report later. Need to measure before I adjust.
H
I also have the spring front end LTX. I installed the next stiffer rear springs and have the adjuster on the #1 setting. Would have been #3 setting with stock springs with no more movement available. When I picked up sled could hardly move front and rear springs. With 65 miles on now they both feel softer.
Please advise as to measurements and testing on front springs. Overall, really enjoying my new Viper.
TestMaster said:I have base LTX so spring front end. Rear set to #2 setting but I have accessory adjuster that has 4 positions vs three on stock adjuster.powerguy1 said:TestMaster said:Using 6" Stud Boy Duallys with 96 1.375 studs down the center. Very very little darting, usually none at all.
LM7800
- Dec 4, 2011
- ohio
- 2016 viper ltx LE sold
how about if you are not studed on a 137?Curve Industries said:Curve riders - go with a 6" Shaper or round bar on your Vipers.
- Sean
Curve Industries
TY Advertiser
- Jan 20, 2008
- Waterville, NY
LM7800 said:how about if you are not studed on a 137?Curve Industries said:Curve riders - go with a 6" Shaper or round bar on your Vipers.
- Sean
Same setup! 6" Round for mild manners and 6" Shaper for more bite.
- Sean
carbides
Running 2 inch on ouside and 4.5 sharper bars on my 129 with the tuner skis.handles great,very low sterring effort.
new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
Hey garyw what rubber stopper (boot) are you using with the tuners ask May dealer said nothing yet and stock does not fit ???
yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
I'm also interested in what it took to put on the tuner skis
ski rubbers
I got a pair of ski rubbers from 2013 nytro.Had to cut them down some with a stanley knife but they fit and work good.Took maybe 15 minutes to get them to fit .
new rob
- Oct 18, 2009
- Viper rtx
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
powerguy1 said:HTestMaster said:I have base LTX so spring front end. Rear set to #2 setting but I have accessory adjuster that has 4 positions vs three on stock adjuster.powerguy1 said:TestMaster said:Using 6" Stud Boy Duallys with 96 1.375 studs down the center. Very very little darting, usually none at all.
Hard to say front setting because it's spring not air. Would say front is factory setting which I will adjust with more stiffness. As suspension breaks in front is definitely too soft, bottoms on moderate-large bumps especially if square edged. If you would like I will measure spring length and report later. Need to measure before I adjust.![]()
Got sidetracked today rebuilding chain case, bearings, seals, gears, chain, speedo side bearing, etc, on friends 98 SRX with his son.
I'll get to it tomorrow morning first thing, will provide left and right starting measurements on front springs.
