alpineviper
- Aug 24, 2014
- Alpine Turbo Viper
guys, my viper has a miss at idle. Drops down to about 1300rpm. Only does it every now and then. It has low comp pistons and rods and a alpine turbo kit. Any ideas ?
This is pretty common and I thought the latest flash was suppose to fix this issue.
alpineviper
- Aug 24, 2014
it has the latest flash....i think its deeper than this.
Some guys even after the flash , it would not idle correctly. Very erratic.
alpineviper
- Aug 24, 2014
it idled fine after the reflash...this kind of just started. Im open to trying the reflash again if thats possible
If it just started, get some good fuel in it and maybe change the plugs. It maybe the temp that you are running it on too.
Could be a valve shim had this happen to me and my buddy. If it is it will only be a matter of time and you will drop a valve. Something you might want to check.
Mtnviper
Vendor
Is it making any unusual noises? If it's ticking, X2 with what stone88 said above.
