STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I am finding I have to go against some of my previous clutching thoughts with these turbo's. I agree these like to be loaded HARD!!. This engine wants to work, not just spin.
What is your total weight?
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
They r around 72 grams but compared to my super tips the weight seems to be distributed more towards the mid and tip of the weight . Hard to compare spring and helix setups with different cam arms. Profile of the weight can make a big difference.
The purple spring is a monster and kills the top end a bit. Steep helix and heavy weights r needed for that baby
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Yeah that purple is mean. I tried the Dalton red but could not get acceptable throttle response on the trail with the helix's I had available. I don;t usually like stiff a secondary spring but with this turbo I am starting to have to rethink some things
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
How do you guy find the time to do all this testing and tinkering? Lol.
When I don't work I want to be out riding in the woods.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I do some of it on the trail. While others are smoking cigs or taking a leak I will change a primary or secondary spring or helix.How do you guy find the time to do all this testing and tinkering? Lol.
When I don't work I want to be out riding in the woods.![]()
STAIN
- Feb 29, 2004
- Vermont
- Vermont
As well as my current set up was working I thought I could leave it alone. Nope. I seem to have some sort of clutching OCD.
More testing.
8JP belt.
Heelclicker black primary spring----140-400
Draggin flies with 2.7 grams in the tail
3.1 grams heel
.8 grams in the tip
77.4 grams total weight
Secondary--51-43 helix, purple spring with 0-1 TWIST---I am kind of married to this secondary set up as softer springs have not given me the kind of throttle response on the trail I like.
Engagement @3000 RPM
Shift out 8900-9000RPM
Slight overflash with cold belt--can't seem to get rid of this and have come to kind of accept it. Maybe a helix change to 53/43 Radius angle? Any thoughts?
Pulls HARD on the trail. Good throttle response on the trail. Pulls RPM in hard pack and powder.
I am tempted to add .5--1.0 grams to the tip to pull the RPM's down to @8800 but I think I might be treading the line right now for weight vs. throttle response. I think I will add some weight to the tail and try again--I can do that on the trail.
I didn't do a full out top speed run, the lake is pretty rough right now with all the ice fishing. That being said top speed is not my ultimate goal. I want this thing to pull your arms off to 100mph
This turbo is really starting to come on.
More testing.
8JP belt.
3.1 grams heel
.8 grams in the tip
YAMMAROB
- Feb 11, 2013
- Dyer, IN
- 2014 XTX Viper Hurricane Turbo,
2015 MTX Viper
Sons: 2009 Phazer Suprecharged RTX Streched to 153
I'm running a hurricane with daves clutch was banging rev limeter out of the hole so I added a washer to the tip still banging talked to dave and he told me to put it in the heal so i movedit to the heal and now its ok out of the hole but now bangs it mid range need it on the tip???
kodak
Rob what primary spring are you running ?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I believe the Hurricane kit uses the stock primary spring....
I would add a small amount to the middle or tip.
YAMMAROB
- Feb 11, 2013
- Dyer, IN
2015 MTX Viper
Witch would be better middle or tip?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Try a small amount (2 grams) in the middle and then drive it. Check full shift out RPM
YAMMAROB
- Feb 11, 2013
- Dyer, IN
2015 MTX Viper
Thanks Stan will give it a try we are very close I might also say i'm 1.6 no studs xtx so it might be different
