Big Mike
- Dec 22, 2015
- Worcester MA.
- 2014 SR Viper xtx
Hey everyone new to sleds and new to forum, names Mike, I have a 14 xtx. Im 6'5" and feel like im leaning over my bars when I stand. Any info on what I would need to do and what risers/bars to run would be greatly appreciated. I believe theres a 6 inch riser now so maybe a 10 inch would suffice??? Thanks in advance!
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Hey Big Mike, Welcome to TY!!
How do you ride? Do you ride trail mostly or off trail most of the time ?
I am 6-3, with my boots probably 6-4 and the vertical steering found on the MTX is the way to go if you stand a lot. I use the 2 inch block but you might need the 3inch. Here is some more info if you want to go that route.
http://www.ty4stroke.com/threads/added-mtx-handle-bar-riser-to-the-xtx-se.131739/
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
I have a 6-8 adjustable on myn and there is plenty of cable to go to 8. on 8 there is still a lot of slack on the cables so im sure a 10 would fit in there fine.
pjabas
- Feb 11, 2013
- Montgomery ,MN
- 14 sr viper xtx se. 153" track turbo
Im just shy of 6' tall but stand alot on my 14 xtx I found my stock riser too short too,I found a great deal on a ski doo adjustable one.. it basically bolted on with minimal about of work, it's taller than the stock one on the lowest position, and I wanna say 8"ish on tallest
Big Mike
- Dec 22, 2015
- Worcester MA.
- 2014 SR Viper xtx
Thanks for the responses guys, I ride mostly trail up in Rangely Maine but im sure with the group of guys i ride with we will be off-trail as well. so im standing for the most part but being this tall is making standing very awkward. and unstable being this low. Stock i believe is 6 inches so I thought a 10 might fix my issue. Other then that I put 175 miles in 1 day on boney whoops trails and loved every second of it. Very impressed with the suspension. Just wish I was more on my feet.
Also does anyone run a bigger diameter grip or bar? I have big hands also and the stock diameter is doing a number on my hands from gripping them. Didn't know if anyone did a renthal conversion or something. Thanks again in advance.
Big Mike
- Dec 22, 2015
- Worcester MA.
- 2014 SR Viper xtx
I see what you did there. does the vertical steering make a huge difference? what did that setup run you?Hey Big Mike, Welcome to TY!!
yamahaguy
Ride SAFE
- Apr 20, 2014
The big advantage of the vertical steering is the bars stay level when you turn right or left instead of dropping down lower. If I remember right it's about $220ish worth of parts from Yamaha. I would recommend sitting on a MTX if you can find one at a local dealers showroom floor so you can see the difference. I am pretty sure you're going to love it.
Big Mike
- Dec 22, 2015
- Worcester MA.
- 2014 SR Viper xtx
Just ordered my powermadd 10 inch block, hopefully have it in time before the weekend. BIG THANKS for all the info, i thought id have to swap cables out but looks like it will be a pretty easy install.
