aca31
- Feb 21, 2012
I just bought a Viper XTX se and just wondering if someone can tell me how much higher I can go with a riser without getting extensions? I'm 6'2" and I would like it 2-4 inches higher. As it sits, I'm slouching over while standing and can't get the leverage I want, it's just not comfortable. If I went with a rox adjustable riser, would I have to buy other things to make it work or can I just swap out what's on there already? Thanks
I have not had time to do mine yet but others have said 2" is no problem.
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
You should be able to go to a 10" riser. I have gone with the vertical riser that Cat offers which is on the 2015 MTX and it can use a 3.5" riser which is about 10".
TJ-R
- Jan 28, 2013
- 14 Viper XTX
I'm using the Rox Speed FX 6" to 8.25" and have it all the way up with no issues. There is some slack in the harness under the dash with the factor riser.
