max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
when using thepressure tool to see where crack pressure is..... is the waste gate supposed to hold pressure, ??? when im testing mine it cracks about 11-12 but will leak dowm .... its a new high end pressure gun and guage. i can pump it up and i stop when it moves arm slightly but then pressure slowly drops and gate closes.....
no1b4me
Needs to hold and not leak, directly connected to the actuator diaphragmwhen using thepressure tool to see where crack pressure is..... is the waste gate supposed to hold pressure, ??? when im testing mine it cracks about 11-12 but will leak dowm .... its a new high end pressure gun and guage. i can pump it up and i stop when it moves arm slightly but then pressure slowly drops and gate closes.....
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i have TD adjustable/boost timer etc and when i use the pump n gage... i pump pressure till arm slightly moves which is 11-12 on gage an then stop pumping but it leaks dwn on gage when i stop.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Are you using the turbosmart wastegate or factory? Assuming you’re using the turbo smart.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
turbo smart from TD with electronic controller
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Got ya, yea the air from vacuum lines in the solinoid should actually force the wastegate shut untill the ecu says to open. Are you sure it’s not leaking out elsewhere since it bleeds down? Also without sled running it won’t make vacuum pressure to close the wastegate and hold it shut, I believe.turbo smart from TD with electronic controller
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
wonder how its leeking dwnNeeds to hold and not leak, directly connected to the actuator diaphragm
- 35K
