actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
13mmAre the turbo bolts a 13 mil or 14 mill can't remember ?
rlbock
Bulletins added to first post in thread by Byam. Actual full PDF is to big to host here so just go to your dealer and ask to see it for now. Will work on getting the whole thing posted somewhere.
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
For those that are having a hard time with the back bolt. Here is what I did.
Sent from my iPhone using Tapatalk Pro
gtrdan24
- Nov 28, 2016
- lehigh valley pa
- 2017 Yamaha Sidewinder Btx 153 Le
RECALLS ARE OUT FOR EXHUAST COVER AND TURBO BOLTS CAMPAIGN NUMBER FOR THE EXHAUST SHIELD IS 090XJ WHICH THEY ARE SWITCHING THE SHIELD FROM A STAINLESS TO ALUMINUM SHIELD AND THEN THE TURBO BOLTS CAMPAIGN NUMBER IS 090XK AND THEY ARE JUST GETTING RETIGHTENED TO SPEC.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
gtrdan24
- Nov 28, 2016
- lehigh valley pa
THANKS ROCKERDAN
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just a repost...its been here on another thread, ''ECU update from Yamaha'', thanks goes to Cannondale.
Dan
Dan
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
No mention of secondary clutch though.........
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Dan
What does the ECU update correct?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Agree...GRRRRRNo mention of secondary clutch though.........
There are some items we find are wrong, but Yammie may never agree with....like coil bind, and could be corrected for 18my quietly behind the scenes or an updated spring, but 17 guys have to do their own fix. Likely cause its not a widespread thing, as many dont ever achieve full shift out and some seem to be fine.
at least rollers will be addressed....interested to see what the new replacement rollers will be made from.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
It is a incorrect post based on a dealer who did not realize that update was for vipers.What does the ECU update correct?
at least that is what we think happening at this time.
If we can get the bulletins we post them in the VIP Section and can view them if you are a VIP, if anyone cares.
Also these are not a recall.Dealers will look for the issue and torque the bolts etc. if your sled is in shop or you have to tell the dealer you have a issue.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
My dealer just called me and said there is two recalls on the sled. 3 bolts and shield. He said they have shields on hand ready to go just bring it in.
