jtill88
- Mar 14, 2013
I need to weld a hole in a 06 Apex front heat exchanger. I have the track out but was told if its welded in place on the sled the ground from welder could burn out electrical components. Is this a fact? What do I need to disconect if so. Supposed to take this in tomorrow afternoon.
attaker28
unhook the battery and I think you would be ok. You have to take the headlight cluster and air box out to get to it.
blue er
I welded mine, just dropped the skid and driveshaft out to do it, unhook battery as safety precaution
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
If you're going to remove the airbox to unhook the battery, unplug the ECM while you're in there. It's just a matter of pulling the plug out.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
northernsledder.jk said:If you're going to remove the airbox to unhook the battery, unplug the ECM while you're in there. It's just a matter of pulling the plug out.
X2, better safe than sorry!
