ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
I have installed the Whal no slip drive sprockets on my Apex. One of the reasons was to run the track looser. Can any one tell me how much tension they are running with there set up? And I would be interested in what Yamaha has for the spec on the new Apex for this year as they now have extrovert drivers from the factory.
thegrizzly1
I do not run studs, and if you do, I would not recommend this set up. I run my track just loose enough so that even with the extrovert drivers it would ratchet. From there I would go 1-2 turns tighter on the adjusters. I think I have 1-1.5 inches of sag between the track and hyfax at the midpoint.
Again this is just my personal preference. I do not have a stock suspension or length anymore.
