tom
- Feb 11, 2005
- Spokane, WA
- www.509films.com
Anyone know what causes the turbo flutter noise? My sled seems to do it more and more lately when I get off the throttle.
Travis Moore
tom said:Anyone know what causes the turbo flutter noise? My sled seems to do it more and more lately when I get off the throttle.
In laymans terms, it's basically air 'backing up' in the turbocharger when you quickly close your throttle plates. You can get rid of this with a blow off valve.
tom
- Feb 11, 2005
- Spokane, WA
- www.509films.com
Where should the BOV go to get rid of this? My sled already has two BOVs.
TurboJamie
Still does it with a BOV.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
are they working.....
tom
- Feb 11, 2005
- Spokane, WA
- www.509films.com
Yea you can hear them working
ripntear
- Jan 2, 2005
Tom it is compresser stall and it happens some times when you do not let of all the way to create enough vacuum to open the BOV all the way.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
You can try to let off some spring tension in your BOV and see if it is more responsive. I had similare situation with Turbo XS BOV. Took one washer off under the valve spring and it helped a lot.
tom
- Feb 11, 2005
- Spokane, WA
- www.509films.com
Do these BOV's require some maintenance after a few thousand miles to keep them as responsive as new?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
a7m266d said:Still does it with a BOV.
Then the Blow off valve is too small for the application.
tom
- Feb 11, 2005
- Spokane, WA
- www.509films.com
Anybody have the Turbo Smart BOV? Wondering how many turns I should back it off to start to get rid of the flutter?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
tom said:Anybody have the Turbo Smart BOV? Wondering how many turns I should back it off to start to get rid of the flutter?
If you can back it off all the way or till it is open at Idle.
