AXR
- May 5, 2007
- Central NY
Hello all,
I noticed yesterday that on my center Qs3 shock the spring had no tension on it and when I tool it back to the dealer (it had to go back for something else) I had them check it and it looks like the top spring of the dual rate combo was broke in 1/2. They are trying to get Yamaha to cover it under warranty but also informed me that the spring is back ordered like everything else..... So I am looking for a quick replacement/better option.
What do you think would be a better choice for me the Zbros or Stingray Mod's (Bill's spring)?
My weight geared up is estimated at being about 250-260. I am thinking that Bill's may not be enough and that I should look at getting the Zbros rider weight 240#+ one?
Any info you can provide would be great. Thanks!
2017 LTX-LE
2017 LTX-LE
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Cannondale on this site will be able to help you with some advice.. He is "UP" riding so give him some time to respond..Hello all,
2017 LTX-LE
RAMSOMAIR
My 17 did the same thing last year and did the Stingray. Worked perfect
fourload
Cat 2704-229 160/260 is working great for me this year.I am 250 suited up. Less bottoming and more transfer with great handling. Just don’t preload it too much. I am at 3 turns from snug. Shout out to Cannondale also for revalving and refreshing my rear shocks. The sled has much more bottom resistance with a nice smooth ride.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I got the 160 spring from cannondale and it wasn’t enough so I went to a 180 and that did the trick. I weigh 300
AXR
- May 5, 2007
- Central NY
Thanks everyone.
-Thanks
Rtbo, Where did you get the 180?I got the 160 spring from cannondale and it wasn’t enough so I went to a 180 and that did the trick. I weigh 300
-Thanks
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
CannondaleThanks everyone.
-Thanks
AXR
- May 5, 2007
- Central NY
Thanks.Cannondale
AXR
- May 5, 2007
- Central NY
Alright. I sent Cannondale a message. Thanks again everyone
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
What is stock strength and what is the Stingray ?My 17 did the same thing last year and did the Stingray. Worked perfect
So the stiffer center spring stops bottoming ?
And helps transfer weight ?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm running this cat spring also. Big difference over the stock centre spring IMO.Cat 2704-229 160/260 is working great for me this year.I am 250 suited up. Less bottoming and more transfer with great handling. Just don’t preload it too much. I am at 3 turns from snug. Shout out to Cannondale also for revalving and refreshing my rear shocks. The sled has much more bottom resistance with a nice smooth ride.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
what sleds is this cat spring stock on ?I'm running this cat spring also. Big difference over the stock centre spring IMO.
How do you tell what spring you have ?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
That part number doesn’t show weight????which model looked like from a 600 but no weight shown
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Crossfire12
- Feb 13, 2017
Got it, ordered thanks a lot
