mattsapex
i hit 120 mph on lake st. clair's anchor bay last season the seld was stock right out of the box no studs or anything i weigh in about 270 dressed blew my buddys zr 900 away.
HONDAFIXER
110 on GPS. Lake with about 1/4 of loose snow on ice
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
One, Million mph..... Bone stock evinrude with twin mice in a wheel.
I've only seen 121 on the DM, clutched, piped, studded (144) cr10EK's, modded air box, lowered....etc...
45 mph
In my back yard....its only 100' start to finish
Plus if I leave marks I am in deep....ya u know!
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I can pull 120 on the dreamo on hardpack all day. Seen 13x? on the dreamo on ice = 118 on GPS.
I weigh 165 on the street.
http://youtube.com/watch?v=Ob8HlOLUXVY
Mikecam
112 gps , 126 dreammeter
iasledder
Honk said:I've seen 134mph, going down a road with a slight downgrade covered with ice. I would guess that this figured out to around 110mph. I have used the hand held, and only can pull 104mph. (Stock)I just tried the trick of grinding off a tooth, I've seen some go two teeth less, and claim that brings it real close.
At 134 mph unless you have extreme track slippage you should be well over 110 mph. At 121 speedo, on my '06 ER on hard pack non studded, GPS shows 109 mph and the GPS is spot on with radar.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I weigh 200# with all gear on. Last year on groomed hardpacked trail with my stock 07 RTX I pulled 124 on the dream-o-meter. Looking to add some slightly larger wheels this year. I will let you guys know if I gain anything.
CuzzinOlaf
119 on the speedo with studs on my 2006 RTX
actionjack
- Apr 9, 2005
iasledder said:Honk said:I've seen 134mph, going down a road with a slight downgrade covered with ice. I would guess that this figured out to around 110mph. I have used the hand held, and only can pull 104mph. (Stock)I just tried the trick of grinding off a tooth, I've seen some go two teeth less, and claim that brings it real close.
I agree, I'd say you were damn close to 120. At 118 on my speedo I clocked 111 on GPS on TQ93.
The Bismarck
Has anyone found that the speedo is off by the same amount between models or they are all different? I don't have another apex that i ride with so i haven't been able to compare.
114 on the dream-o-meter. Fairly hard-pack on lake Gogebic. Loaded Yammi saddlebags. 07 Attak gt, 162 studs up the middle, Simmons skis.
165 lbs without gear.
Dano
actionjack
- Apr 9, 2005
You'll go faster at 33 degrees
RTXs
BlueByYou2000 said:RTXs said:My sled needs HELP!!!! 06 RTX with Ulmer stage 2, 144 gold diggers up the middle only seeling about 108 - 110 at best on the dream meter on hard packed snow, 10,800 rpms. Just barely out runs my buddies 600 sdi. It really rips out of the hole though (shorter races i have beaten several Apexs)... not sure what to do. I have discovered some idler wheel bearings were shot, will check em all soon. Any suggestions?? maybe try 23t top gear?
Put in that 23 gear.
Ill try the 23t top gear, i gonna take a look at my clutch also, maybe go back to the original clutch.
- 7K
- 6K
- 9K
