TrueBlue
Both a 2018 Vector, what type of oil in the engine. This is not a yamacat. Is it regular oil or semi syn.from the factory.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
My guess would be 0w30 semi synthetic. Probably lists that and 0w40 full synthetic as an alternative.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
IDK.....sorry for not reading the question correctly.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
they come with semi synthetic when new.
TrueBlue
Thank's for all the replies.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Don't use full synthetic until after break-in.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
That's an old wife's tale. Syns can be used at any time even during break in. Today's engines are, for the most part, broke in already from the factory so they are nothing like the engines years ago.
Many new vehicles/engines come straight from the factory with synthetic oil already in them. My big reason for using nothing but syn is the cold weather benefits and the protection syn provides compared to dino oil.
Myth: You should break in your engine with conventional oil before you start using synthetic oil.
Again, there’s no manufacturer we know of that makes this recommendation. Mercedes, Porsche, Corvette, some Cadillacs, Volkswagen, Hyundai and many other manufacturers’ cars come from the factory with synthetic oil.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Actually your both right. Full synthetic can be used for break-in but it’s really a waste because your going to drain it after 500 miles anyway. Full Synthetic oils don’t protect any better than conventional oils, but they do break down faster.
I do like the cold startup protection of a synthetic but if you let your sled warm up before you ride it your golden. It’s been proven that some conventional oils protect better, it’s the additives in the oil that really matter for film strength.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
I would like to see your data on that, and from a third party lab. Pretty much any brand name full synthetic oil will out perform any conventional oil. Just look at all the new car engines, they generally now call for full synthetic 0W20 oils. Since most of the engine wear occurs at start up, especially for us in the cold weather, full synthetic 0W rated oil is the way to go. On sale, full synthetic oils are only a fraction more than conventional or semi-synthetic oil, so going to a full synthetic is a no brainer.It’s been proven that some conventional oils protect better, it’s the additives in the oil that really matter for film strength
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Pretty Much any brand eh?????
You really don’t know what your talking about just assuming all synthetic oil is better than conventional Dino oils.
Here ya go the second oil on the list is a conventional oil.
http://pantera.infopop.cc/eve/forums/a/tpc/f/5650045562/m/1631078456
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Also please note also that every “Break-in” oil is conventional not synthetic.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
That's not true.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Well most are maybe I missed one in the test?That's not true.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
What is true is the fact that many conventional oils out perform synthetics but their time is limited. Synthetics last longer.That's not true.
As for new engines not needing break-in.....also false. How many manufacturers use a torque plate to hone their cylinders? Let me tell you, none. Do they finish plateau hone with a diamond stone? Nope don’t do that either. Yes it’s much better than the old days but you really should break-in any motor if longevity is your goal.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
My head hurts after reading this.
Forget about the break period, what's the best oil to run in:
1. Yamaha 4 stroke snowmobile engines? I've been using Mobil 1 0W-40 Euro oil for years now.
2. My air cooled 28hp Kawasaki twin cylinder 4S motor? This motor is on my zero turn mower. I've been using Valvoline 15W-50 (?) full syn motorcycle oil. This motor is 3 years old and has 210 hours on it.
