amazza76
- Feb 21, 2013
I have my suspension pulled and need to replace a wheel on the axle that bolts directly to the tunnel. There are no c clips and I tried to pound the wheel off with a lead shot hammer but the wheel broke and left the bearing behind. How do I remove the old bearing and get the new wheel on?
gitrdun
If we are talking about that simple shaft that connects the two wheels, you can take the other wheel off and find a 6"long piece of pipe a hair larger and use it similar to a slide hammer. Penetrating oil first wouldn't hurt. Normally it should slide off easy, so could just be crud from on there to long, inner bearing distortion, or someone used too many man/pounds torque to tighten that bolt. You'll get a better idea when you go to put the new one on.
